Story Stiffness
Attiq_ur_Rehman
Salam,
I have a query regarding finding out the story stifness of building structure.
I have modeled a building on Etabs and applied applied UBC Zone-3 lateral loading on it. Ran analysis and then from "show tables" i selected show "story stiffness" and i got a table showing story story stiffness of each story in both (x and y) directions.
But when i modeled the same building and applied time history function and selected to show story stiffness from show tables, ETABS is not showing any story stiffness at all. Can anyone explain what is the reason of it?
Your story stiffness is independent of the type of load as long as we are talking about the elastic response (Linear Static). You can use the same story stiffness or calculate yourself manually for each story by applying a  1kips load and then finding out the corresponding deflection and diving 1kip by that deflection,.
I don't know why the software isn't showing you. Maybe you aren't doing a linear time history analysis. I am just guessing.
  • 2 years later...
On 10/21/2018 at 4:01 PM, Attiq_ur_Rehman said:
Salam,
Found any solution ?
