Upward Soil Bearing Pressure Calculation
Rifat
As salamu alikum,
Anyone can tell me the process of this calculation-
Quote
Mat data: L=38',B=15.5'
DL=170 psf
LL=30 psf
Bearing capacity of soil=1.05 tsf.
No need to calculate column load,say there are no column load.
How to calculate upward pressure of soil by manually or by any suggested software?
Thanks in advanced
You will need to get familiar with Terzaghi and his factors. Start by determining the internal friction angle of the soil. This can be assumed or determined analytically by testing the soil. Based on the angle of internal friction you can determine the bearing capacity factors for general shear denoted as N.c N.q and N.y (y=gamma).
The general equation for ultimate bearing capacity for shallow continuous footings is given as:
q.ult = 0.5*(gamma)*B*N.y + c*N.c + (p.q + y*D.f)*N.q
Where:
B = width of the footing
c = cohesion of soil
p.q = surcharge pressure
D.f = depth of the footing
Once the ultimate bearing capacity has been determined, find the net bearing capacity by subtracting out the overburden, typically given as y*D.f. This is the net pressure the soil can support beyond the pressure applied by the existing overburden.
Now simply divide by your factor of safety (3 is typical, but can be as high as 6) and viola, you now know your allowable bearing capacity.
*If you are interested in this information for any heavy civil projects, you should consult a geotechnical engineer who will give you the actual allowable bearing capacity of your specific soils on site. Structures should not be designed without having actual tests performed on the soil. The above information is provided for academic purposes.
Use the information above and calculate the bearing pressure yourself.
