Petrol tank foundation
Mukhallad Murad
On 11/20/2018 at 11:47 AM, Mukhallad Murad said:
I have petrol tank 30 ton  rest on ground its size 10x 5 m . I wnat to design raft foundation but the tank it rise by 0.5 m from top of foundation.Is foundation will design for uniformally load or concetrated load depends on supports (0.5 m) and how the load will be on supports
You can provide a big pedestal that can support the tank and have a raft below. If the tank is supported on steel skirt (circular steel vertical ring) this is mostly the case for vessels, then you should apply the load as line load. If that is not the case and the tank is a simple tank (flat bottom), then just provide cementitious non-shrink grout between your pedestal and underside of tank and apply the load as UDL on the pedestal.
Let me know if you have any additional questions as work in Petrochemical Industry and this is very common.
