FEA Research Paper
Shahzad Khan
Aoa, hello guys, Idk how to start problem here but let's just make it straight. I'm studying FEA in my Master studies and the teacher has assigned me task to select any research paper based on finite element analysis, provide summary of research paper and regenerate the results using software. I selected a research paper, which was based on comparison of results of strap footing settlement using SAP, ETAB and manual calculations. The comparison was for results. I reproduced the same results in software and submitted to my course instructor. He rejected the results and told me to select any research paper which actually shows what happens inside the structure and regenerate the results. This project carries 15% weight of subject marks. I'm unable to find research paper which actually shows the required results. If you think, it's possible, please whatsapp me at --- ASAP.Put your reviews here too. JazakAllah.
Edited by UmarMakhzumi
Phone Number Deleted.
Wa alaikum us salam,
SAP and ETABs do not work fully on FEA.
You should use paper showing results regarding stress distribution, strains, etc. Search for papers using softwares like ANSYS, LS DYNA, DIANA, ABAQUS, ATENA, etc. Right now, for initial stage, I would recommend you to search for FEA of simple beam.
Let me know, if you require any further help.
You can use the following paper. it have manual verification as well. But I hope you should try doing it yourself and then check the manual verification. because learning is more important
Crack Identification in Reinforced Concrete Beams Using ANSYS Software
L. Dahmani,a A. Khennane,b and S. Kacia
