Post Tension Slab Design using ETABS 2016
MKhalid
Assalam o Alaikum,
I'm facing a problem related to the analysis of PT slab in etabs. After adding tendons in column strip the -ve deflection is increasing instead of decreasing. This is my first time that i'm doing PT slab analysis on etabs. So, i might be missing something. Please help me out. I'm checking deflection on combo of PT-FINAL + DEAD.
If you are doing it for the first time i would recommend you do the PT design manually to understand the behaviour of the forces first as the stresses equivalisation in the slab is important. you can deal wth the column strips individually. The diaphragm reinforcement interaction with the PT alos needs to be looked in detail. So that the location of reinfrocement is right. u would suggest use PCI manual for the basic design. Maybe someone else give you a hint on ETABs but i belive if you are doing something  new in software than there are alots of variable which you can comprehend in the first analysis. I hope it helps a little.
@Nustian371 can you recommend or share any book regarding PT for beginners? My email is " engrahsanali92@gmail.com "
