SAFE Design strip widths - How wide strip should be?
Hasan009
Hello,
I have question regarding the width of design strips. Please see attached plans. We have columns only at Grid line SM and wall at Grid line SB and Grid line SM. Spacing between Grid line SB and SM is 14.05m.
Right now, strip widths are 7.025m. Attached please see plan.
I also tried putting one more Grid line between SB and SM making design strip width to 3.5125m.
Moment per meter values are higher for this plan as compared to Moment per meter values for 7.025m strip width. Please see below:
For 7.025 m width:
+M=259 kN-m
-M=-526 kN-m
V = 345kN
For 3.5125 m width:
+M=410.53 kN-m
-M=-897 kN-m
V = 731 kN
Difference is huge. Please advise is there any document to read for column strip, I could not find any clause for maximum design strip widths.
Thanks,
X- direction strips 3.5125 m.pdf X- direction strips_7.025 m.pdf
Edited by Mumtaz
  • 4 weeks later...
Mumtaz,
Ít all comes down to engineering judgement. Would you draw a wider strip if there is a point load? Obviously no. The codes allows L/4 strip widths for uniform loads. Obviously you will get more moment/m for a wider strip as compared to a less wider strip around moment concentrated elements like walls or columns.
