How to apply insertion point to frames in Sap2000
in default condition the beam will lies at the centroid of beam and will not take any force but when we apply insertion point to fame the rebars in frame/beam significantly reduced due to reduction in moments and these moments converted into axial force in beams. is it correct way to use this feature. please guide.
Your results for insertion point will depend on how the two members are being connected but generally speaking, using insertion point should make your results worse  (increase reinforcement) instead of reducing it as there is now additional moment being generated due to eccentricity of centroid.
no it will reduce the moments kindly search it on internet it will reduce the moments in beams and columns and make the beam to behave as T-beam. if you have experience this command in sap2000 then please comment otherwise don't spread the false information.
I have explained to you why that is not correct. Insertion points other than center modeling will result in additional moment, that is how software resolves nodal forces. If you have a counter explanation (not a fake article on web by some idiot) please post.
