Modelling of Retaining walls and BackStay Effect
Gerald Elusen
Hi Engineers
I have to model a building with 4 basement levels. Do i need to include retaining walls on my Etabs model?
Does Etabs differentiate between shear walls and retaining walls?
What i am trying to avoid is to make my structure so stiff that it attracts a lot of forces while in the real sense its not.
Thanks for your comments on this
warm regards
Gerald Colyvas
  On 7/5/2019 at 7:50 AM, Gerald Elusen said:
Hi Engineers
warm regards
Gerald Colyvas
That must be a basement wall a type of retaining wall.
The design of shear wall and retaining wall is no different, u just need to add in the load of the soil retained. the load can be added through the option given below.
You must include them in the model. In addition to resisting out-of-plane forces, in the form of soil pressure, it will resist in-plane forces even if the base is located at higher level due to back-stay effect. You can find the approach to tackle it in following documents.
https://www.structuremag.org/wp-content/uploads/C-StructPractices-Tocci-June121.pdf
http://www.tallbuildings.org/PDFFiles/2017-LATBSDC-CRITERIA_Final_w_2018_ Supplements_FINAL_20180320.pdf
