Modelling of Nicholson's Obelisk in SAP2000
Howard Roark
I am working on modelling of "Nicholson's Obelisk" (located in Taxila city) in SAP2000 for identification of its dynamic characteristics and mode shapes as well.
This is how structure looks like.
This structure is made up of Granite stones only. I haven't modeled a "Solid model" before, I have been trying to model this structure for past few days but have been unable to model it. Problems I am facing are following:
1- In SAP2000 which section property should I use for modelling this structure? Should I consider a wall section or slab section?
2- Should I opt for some other software instead of SAP2000?
3- How can I model the tapering of the structure in software?
After getting fed up using SAP2000 for modelling, I tried ETABS for modelling base of the structure but the structure didn't read any object and this is the error displayed
But when I modeled the base in SAP2000, this was what I got
 I have to submit this model by Monday and it's last deadline, so any sort of help regarding modelling of this structure would be highly appreciated.
Let me know if you have want more information concerning this structure.
Edited by MuhammadUsman
This is no different than a shearwall. You can view the tutorial below to see how you model walls in ETABS.
It depends but Sap2000 and ETABS are equipped with some great tools that other softwares lack.
You can but try to model a rectangular one first. The meshing will get tricky with tapering and your model will generate a lot of errors (although tapering is not that difficult to do) but stick with rectangular one for simplicity as you are new to this.
Well, if you want to do a fancy accurate looking model, I would recommend using solid elements.
The image shows that you are using shell elements and with those elements, modelling layers is fairly tricky. As a starting point, just model a single base. Ignore the tapers and model straight walls, get your results and keep it simple.
Hope that helps.
The warning/error you are getting in ETABS shows that there is no line element in your model, only shell (area) elements and you are trying to display frame/pier forces etc.... Go to  Display for displayinh shell stresses/forces...
Share more detail about the subject model like base dimensions, height etc and a plane of your model/structure.
Edited by EngrJunaid
