Design of Footing in ETABS 2016
Assalm-O-Alykum
can we design footing in ETABS16? If yes then how much reliable that design will be? If any senior have experience and he/she  carried out footing design in ETABS16 please share your experience with us.
Thanks in Advance.
I had tried to do the design of slabs and foundation in ETABS, it is very good and better than SAFE and easier. The drawback of designing the foundation in ETABS is that the full model work together and any change on the foundation sizes or thickness, it changes the stresses on the full system not only the foundation which force you to check the model more than one time to make sure your design is safe. Actually, this way leads to perfect design, but you will lose a lot of time in doing the alterations.
Thank You very for the information dear Husam AL-Mufaji
I had also tried to design footing in ETABS 16 and found the same results.
 I have question after assigning area spring to footing slabs when i start design and check bearing pressure it gives 0 PSF value. is this any model error or something else? Please guide.
I done a trail and I got correct soil pressure on the footing as you can see on the attachment.
I also attached ETABS trail file for your reference.
If you still did not figure out the solution, please upload your model, so I can see what is the problem.
Trail Model - Footings.EDB
Thank you @Husam for your efforts and sharing your Trial model.
I have checked the model and few questions to ask.
1) Normally we have only bearing capacity available from client to design foundation. So how to calculate Area springs value from that bearing capacity.
2) Your model is not calculating Punching Shear. It displays N/C.
3) Please explain the Isolated Column Footing and soil profile options given in Define ---> Spring Properties ---> soil profile and isolated column footing.
My pleasure Fawad,
1) to calculate area spring, you have to divide SBC by settlement and multiple with safety used to calculate the SBC. Normally, Geo-technical engineer take 2.5 to 3 as safety factor. ((SBC/Settlement)*FOS).
2) I am really sorry, I don't have the Ultimate Version to check. I used to have it, but I don't remember if I check the punching on the foundation or not. I done it on the floor slabs and it is working fine. Try to create a raft slab instead isolated footings and check. Maybe the footing too small where the punching shear parameter fall outside.
3) I didn't tried to use any of these.
How I landed here through google is that I was looking for "how to assign soil profiles columns in etabs?
another path google showed to me is "https://wiki.csiamerica.com/display/etabs/Soil+profiles+and+isolated+column+footing".
@Husam: In above method that you mentioned, only strength design can be carried out, but the important thing for iso
footings is the stability, overturning and sliding which can't be checked this way!
  • 9 months later...
My greetings firstly, I don't know if I am late for this topic but it might help somebody.
I think when you defined the area springs the "spring constant/ unit area" in the direction 1 and 2 are too large, and when removed in those directions give reasonable soil pressures
