Beam flexure ultimate equation
WR1
Back to the basics,
Just faced this issue where a retaining wall (assume it singly reinforced section) had very less capacity with provided As.
However, when calculated the stress, it was found out to be less than modulus of rupture and hence safe.
Why is the discrepancy and when one should use the ultimate design? I understand the reo will start working only after Mcr has reached (cracking moment).
5 hours ago, Rana said:
Back to the basics,
As far as I believe you have to provide steel in any case when designing for flexure. The conventional conservative approach is that whether the section is cracked or uncracked it is assumed that all the stresses are carried by steel on the tension side. However the concept of cracked and uncracked section is useful in controlling the deflection.
I have not understood that why are you thinking that there is some discrepancy.
As far as the ultimate design is concerned, I believe you mean: strength based design. This is the only procedure that we follow. No body uses working stress design procedure.
As far as your wall is concerned, it is not necessary that every structural component that you will encounter in actual structures will be subjected to a moment which is at-least grater than the cracking moment.  If the demand is less than what is require to cause stresses-inelastic-section-cracked situation, the strength design is not applicable on the cross-section. However, the section must have minimum reinforcement to initiate ductile failure as per applicable code.
This is it. So in short, if Mcr has not reached, strength based design equation does not apply.
