Load Calculation
Nawaz Qasim
When Calculating external wall load  on ground beams (FFL +0.3) Should I take the total wall height on of all stories or just the story above ground beams?
by total height I mean (Height  of the building to where wall extends (T.O.P +9.00)x thickness of wall in elevation x density (assume 18 kN/m3) ?
or take wall height up to (FFL +3.90) x thickness x density ? Please Explain ?
Load to be calculated on ground beams!!!
Wall Loads are calculated only for individual floors, Like for Ground beams you will consider walls of ground floors only. Please refer the attached pics for a clear understanding.
Also for dead loads and density you can refer to the attached ASCE-10 pages. Where the densities are given including the plaster.
ASCE 7-10desity.pdf
