Difference in calculating minimum reinforcement when using limitations imposed by aci for beams and slabs
abbaskhan2294
Following are the limitations imposed by ACI for calculating minimum reinforcement in case of slabs and beams:
As (min) = 0.002 bh or 0.0018 bh (for slabs)
As(min) = (200/ fy ) b x d ( Governing for beams when fc' < 4500 psi)
I tried to calculate isolated footing flexural reinforcement with both these methods and the results were quite different.  Eq of slab when used gave me a min reinforcement of #4@8" c/c whereas beams equation gave a minimum reinforcement of #4 @ 4" c/c.  My question is when to use each of them in footing and which one is the more reliable approach to use. Thanks
Edited by abbaskhan2294
