Etabs Torsion & Longitudinal Rebar Output
Rifat
I having a problem understanding the design output in Etabs in a RC structure.
For a given beam concrete design check, i am getting the following results in a certain beam section:
1- for Longitudinal reinforcement: TOP= 1.5 in2
                                                             BOTTOM= 0.9 in2
2- Shear reinforcement(stirrups): 0.3 in2.
3- Torsion reinforcement:A- 0.4 in2   B- longitudinal reinforcement= 2.17 in2
my questions are:
A- For the stirrups should i go with the shear requirement since its greater or should i add the shear+torsion requirements and design the beam stirrups accordingly?
B- For the longitudinal reinforcement, should i go with the Torsion requirement since its greater than the flexural requirement or add both Torsion + flexural requirement?I try to solve this in a way that is-From etabs shear,moment,torsion results after manual calculation I get torsion longitudinal rebar,Al which is much less than torsion output which we get from Etabs Concrete results.The screen shoot is given below.
guys your help is much appreciated, i can't move on with my project until the above points are covered. thank you so much in advance and may god bless you.
  • 4 months later...
