Ground Motion Data Conversion
Engr. Muhammad Farhan
Anybody knows, how to convert the the Ground Motion data from Frequency from to Time and Acceleration (Time History) form. Actually the shake table test has been performed and sinusoidal ground motions are used as see in attached file. Now for numerical simulation purposes, i have to use this ground motion data in SAP2000 where the data required should be in Time and Acceleration (Time History) form.
Fourier transform equations are used for this purpose. You can easily do it on Matlab. I am curious to know how the time domain of above three signals will look like. As all frequencies of a particular test run has the same amplitude,  Fourier spectrum will be a straight line. It does not represent a real earthquake/ or real ground motion.
On 11/25/2019 at 7:05 PM, Fatima Khalid said:
You can use SeismoSignal software as well to convert time domain to frequency domain and vice versa
Ok Thanks.
How i can convert the above data into time domain using SeismoSignal ?
Could you please help me ?
Could you please share the algorithm regarding conversion ?
