Structural Design Codes in Pakistan?
Simple Structures
Can someone help me determine the "standard design codes" to be used in Pakistan for designing building structures;
The Pakistan Building Code is a 'cut & paste' document with little practical guidance - hence superfluous I would say.
Which codes do you use for 'structural design of elements’?
1. Wind Loading -?
2.  Concrete design -?
3. Steelwork Design -?
4. Masonry design -?
5. Timber design -?
6. Geotechnical design -?
7. Earthquake design?
& so on etc etc.
There is the American Codes (ASCE, ACI, AISC, ADM) and European Codes (Eurocodes, EN, EC0, EC1, EC2 etc) for each of the above and more;
Should Pakistan be adopting Eurocodes with the Turkey's Nationally Determined Parameters?
Who is the custodian of the design codes ruling in Pakistan? PEC (another of the country's quango that is more interested in ticks box exercise, or am I wrong is that assumption) or is there another body that one can look to for guidance?
Any feedback on the matter from learned Members would be most welcome.
Edited by Simple Structures
This is a great question. I will share what I have been using:
1. Wind Loading -?
Mostly ignored it while working in Pakistan as seismic governed. For cases where had to consider UBC 97 was used. At some project I also used IBC as I had a supplement that provided the environmental parameters for wind, seismic and snow.
ACI 318-02
AISC 360
Zilch
5. Timber design -?
Never did.
Consultant in all the cases.
ACI 318-2, UBC 97 mix
& so on etc etc.
In addition to above, I once got the chance to use Eurocode for a British Embassy Project but that was exception to the rule.
Pakistan should work on improving it's own code. We would be better off improving on American codes as people are more familiar with them.
I think you can get contact information on this if you have a copy of Pakistan Building Code. please see the following link for more details:
https://www.pec.org.pk/building_code_pakistan.aspx
It would be great to see what others have been using in Pakistan.
1. Wind Loading -?
5. Timber design -?
& so on etc etc.
All the design codes are well-mentioned by Umar. As far as timber design is concerned you can refer to NDS (national design supplement) and AWC ( American wood council) documents. The wood engineering properties are based on species found in US and cannot be used for Pakistan timber industry. The potential of timber in Pakistan still needs to be investigated.
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
