Modal Analysis interpretation
Talha Rasul
I am attaching the modal participation of mass of building
first mode and second mode time period is quite apart that is good but first mode seems to be torsional
help me out if ETabs modal results are placed as first torsion then followed by x and y .
I want to interpret the results if these are good that I can lock my structure and go into designing?
824369733_F9E4218E-284E-49D6-B61B-77F239E06B1B.png.thumb.jpg.a2094e1acc83cec014633538e43209d0.jpg
Moreover these are my center of mass and rigidity they are also 7 to 8% apart so I want to know if my building first mode is torsion.?
Yes your first mode is in torsion. To avoid torsion in the first mode you need to keep the mass participation ratio for Rz below 5% (.05) and below 10% (.10) in second mode. Also how many mode should be evaluated depends on the number of storey.
In addition to this also check that whether the maximum deflection at corners are less than 1.2 times the average of corners.
Yes, 1st mode is torsion and it is good that translation and torsional modes are well separated (1.23s and 0.48s). However, I can see the sum of mass participation is still not 90%. Bring it up by including more modes, and then check results. There is no problem having 1st mode as torsion as long as you design for it. However, the building framing will be working very hard and is not very efficient against lateral loads but no is stopping you to not have 1st torsional mode.
Hi Asif, I am very much interested to see if there is any reference for keeping Rz below 5% and 10% for 2nd mode?
I am really interested to know the reference of your statement and how we can achieve that in etabs?
