IBC code use instead of UBC 1997 in karachi
kHURRAM ALI
Aslamwalekum to all,
I am designing a building located in karachi , which lies in zone 2B , soil type Sc as per pakistan building code (PBC) ,  from (PBC) i extract seismic parameters like Ca and Cv , but when i switch to IBC it required seismic group, Ss , S1 , site class e.t.c , all these parameters can extract from IBC , but for karachi there is no info available, from which i can get these parameters , so how do i find these parameter for my design , is there any correletaion between UBC and IBC parameters by which i can extract these , please help
thanks
There is no correlation between these parameters. Maps in UBC are based on 500 year return period (10% in 50 years), whereas as in latest codes maps are for risk-targeted earthquake having 2% probability of exceedance in 50 years (2500 years return period). UBC maps are in terms of PGA whereas now the correlation parameter is spectral acceleration.
However, people have done work on this and you can get these parameters from their papers. Please get these values from following studies.
Bhatti et al. 2011 Probabilistic seismic hazard analysis of Islamabad, Pakistan.pdfFetching info... Ahmed 2019 Probabilistic Seismic Hazard Analysis Based Zoning Map of Pakistan.pdfFetching info...
@kHURRAM ALI, Wa alaikumas salaam at first.
Secondly, there is no correlation between the seismic parameters between UBC and IBC. There should be a map developed for your location by your authorities(if general design guidelines are through American Standards and you don't have your own design code). That map will give you the spectral acceleration values at short and long periods. Otherwise, as I remember, there is a standard which gives values of Ss and Sl for international grounds, you can refer it for values in your city and proceed with your design.
