vertical spring for Slab on grade - Calculation?
Hasan009
I am modelling a box structure, I have horizontal subgrade of modulus from Geotech. I know how to calculate horizontal spring constants.
How would I calculate Vertical spring constant? Is it Modulus x Area of plate (1m x 1m)?
Edited by Hasan009
 1.     The geotechnical engineer - the soil specialist - should provide you the modulus of subgrade / elastic spring stiffness in his SI Report. Get in contact with him - this is the best and safest option. He is best placed to offer advice.
 2.     I have found that the geotechnical engineers often provide subgrade modulus to structural engineers by undertaking a CBR test, and then correlate the subgrade modulus to CBR value.  They use a (0.6m x 0.6m, or) 1m x 1m plate for the test. The reason they don't do it that they would need to bring in heavy weights to do the test, hence they don't bother! I am sceptical of the CBR test as it only gives the strength of the soil in the near surface - In my view it does not give much of an information at depth.
 3.     In the absence of any information consult Bowles book on Foundation Analysis and Design  I know has a table - which gives the different ranges of subgrade modulus based on various soil types. I don't have the book handy but recall it from distant past. If someone has the Bowles book handy, then they can help.
