Link Properties in SAP2000
Ayesha
I came across this today and thought it would be good to share.
Problem:
While connecting 2 different elements, using links with Fixed end conditions would not report any forces in the link elements.
Stiff behavior may be specified for any Link degree-of-freedom (DOF) by selecting either the Fixed Behavior option, or by assigning a reasonably large stiffness value, as described in the Rigid behavior article. The Fixed Behavior option is convenient for simulating either a support restraint or a constraint between two joints. In general, however, a link with fixed DOF should not be directly connected to other objects with fixed DOF, or to joints within a constraint condition. In such cases, we recommend using sufficiently large stiffness values on the order of 1e11 kN-m (or kN-m/rad). Large stiffness values should also be used when forces must be reported for the fixed/stiff DOF, and when adding or removing links during Staged construction.
https://wiki.csiamerica.com/display/kb/Fixed+DOF+in+links
Solution:
We recommend using sufficiently large stiffness values on the order of 1e11 kN-m (or kN-m/rad) to model the rigid behavior of concrete systems. Formulation is explained in the Bearing and foundation springs article. Sufficiently rigid stiffness values may be assigned using spring constants, property modifiers, section properties, or any other method which will produce the desired effect. This modeling procedure is typically adequate when rigid stiffness is not too large relative to the stiffness of connecting elements. Otherwise, linear problems may experience numerical sensitivity, and nonlinear problems may fail to converge. Restraints and constraints may be used to avoid these computational issues, but forces will not be generated, and additional problems may result from coupling behavior.
https://wiki.csiamerica.com/display/kb/Rigid+behavior
Edited by Ayesha
