(6/5) Beam/Column Capacity Ratio Adjustment
Osama Anwar
Assalaam o Alliakum Everyone.
ETABs 2013 does not show any warning if (6/5) Beam/Column Capacity Ratio is greater than one. I have to select (6/5) Beam/Column Capacity Ratio from Display Design Results Option to view my columns failing the criteria (O/S#33) it doesn't display the columns failing the criteria otherwise and the ones failing the criteria are not red also. In preferences my seismic category is D and frame type is sway special.
Is it Ok to proceed without adjusting it if ETABs does?
Will my structure still have strong columns and weak beams without it?
Or would ETABs give warning once I have detailed the building?
Salam,
B/C CR is normally displayed for SMRF for seismic zones 3 and 4. You may check the beam and column section capacities manually and have some idea of the weak beam strong column, detailing rules also help, keep the column sections larger than beam section, keep your beam inside the column width.
Cracked versions sometime have some problems. Search the forum for this topic there are many threads for that. here is one.
  On 6/22/2020 at 7:45 AM, waqar saleem said:
Salam,
Thanks for the reply. ETABs is giving the ratios based on reinforcement proposed by it. Introducing reinforcement manually in columns in section properties causes a drastic decrease in the ratio (i.e. by setting the option from "To be designed" to "To be checked"). But still the beams moments are based on the steel area provided by the software. What is your comment on that? What should I do?
