RC gantry beam design
Salman Maqbool
Hello
I am designing an rc  gantry beam of 80 feet span crane loads. The problem I am facing is regarding the stiffness modifiers. According to aci we can use 0.5Ig modifier for beam when checking for deflection.
Can I increase this modifier to 0.7Ig or 1Ig for checking service deflection. The allowable deflection for the gantry is L/2000 as notified by the supplier.
I think stiffness modifiers dont apply to local checks, so you can consider the full moment of inertia. The intent is more for global analysis, I believe (not 100% on this). Having said that there were recent conversations on the forum on stiffness modifiers. I would suggest that you search the forum as well.
You need to use ACI 318's equation that relate service-level moment, or the moment against which you need to compute your deflection, to effective moment of inertia. The equation is 9-8 in versions before 318-14, and it is given in table 24.2.3.5 in the 2019 version of ACI . You shouldn't arbitrarily choose the factor.
