Creep and Shrinkage Deflection Calculation in SAP2000
Shahzad Khan
Aoa! I want to compare deflection of a R.C.C Simply supported beam using Manual calculation and verification with SAP2000. My question is how does SAP2000 consider creep and shrinkage in deflection calculation for ACI Code, Australian Code and Euro-code (If Australian Code and Euro-code is available in SAP2000)? Please explain briefly.
If i am not wrong, as per ACI Code the deflection calculated for a beam should be multiplied with creep and shrinkage coefficient after immediate deflection value.
yes you are right the creep and shrinkage coefficient is used on the top of ULS/SLS deflection limits.  SAP2000 do the analysis for creep and shrinkage if temperature loads are applied or long term short term loading are self defined. Otherwise SAP2000 deflection are only for loading applied.
Thank you for feed back!
  • UmarMakhzumi changed the title to Creep and Shrinkage Deflection Calculation in SAP2000
