I want to build 3 floor building on my 128 sqy corner plot
salam alykum
I want to build 3 floor building on my 128 sqy corner plot after demolish old house in korangi 5 area karachi ,, i already draw map myself (attached) but i could not give sizes of rooms,bathrooms, hall,kitchen,stairs, etc etc
actually i don't have any idea regarding construction, and i am afraid about labor and contractor which easily cheat me in this process to use low quality materials,
can anyone engineer help me out in this issue ...
Wise move to get the structural design and construction right. Many people are confused with the roles of the architect and the structural engineer.
If you imagine the human body then the Architect decides on looks, colour of skin, how much fat, appearances generally etc. Whilst the structural engineer determines the bone structure (skeleton make-up), the joints cartilage, tendons etc.... and how the body stays stable under a heavy load, against strong wind loading, and even during earthquake ground motion.
I am not sure if I can recommend someone on this platform - here to help. So...
Hence, I have forwarded you an email details of someone who will able to help with Structural Design & Drawings complete.
Visit: www.pase.pk
Normally: This is what you need:
1. Architectural layout and elevations - By an Architect or prepared by yourself.
2. Structural design and detailing drawings and specification (inc foundations) - Structural Engineer can only do that - not an architect!
3. Drainage Design & Details - can also be drawn up by most structural engineer - normally public health engineer.
4. Electrical & Mechanical design (sockets, switches, lights AC etc locations are normally picked up on architects drawings) - by electrical/mechanical engineer, or yourself if you know what you want and where.
Hope this helps,
    • Hi, I have a similar scenario where the truss is subjected to both wind and temperature loading. I have assigned a hinge and roller support to the truss; the roller is translating in both directions because of wind and temp loading. To accommodate movement, I am using a ball bearing with stopper plates to restrict excessive displacement while providing the necessary deflection allowance. My Questions: 1. If the ball bearing comes into contact with the stopper plate at its extreme deflection limit, will the connection start behaving like a hinge? If so, do I need to check my truss supporting beam for additional reactions due to hinge behavior? 2. Would using a Teflon bearing plate solve this issue, or would it also behave like a hinge once it reaches its displacement limit? ( I donot know  teflon plate behaviour) For example, if the truss deflection exceeds the allowable displacement range of the Teflon plate, will it introduce unintended forces at the connection? just like roller and stopper plate connection Would appreciate insight, Thank you   Please advice
    • Hi, Greetings sagacious colleagues, As per the attached pictures, could anybody assist me regarding the following concerns, Why is NDT required, if not why? Method of repair and what will be the plan on the damaged reinforcement, especially the main bar, will it be cut and use a new one through spliced (welding, stirrups, etc.)? Which type of material is to be required? Thank you.
    • Strength design lateral loads
    • Should drift be checked in strength design condition or service condition of structure?
    • etabs solve this quite good. or you can use prokon to calculate shearW
    • Send the model included. 3m is too long for a normal cantiliver beam
    • Joint assignment for RCC Wall in basement in a frame structure modelled in SAP2000 Hello, I am designing a frame structure in SAP2000 which has a RCC wall in basement upto the bottom of floor beams.  Should I divide the wall into 2'x2' squares and then assign fixed supports to all the wall shells or not?
    • The cantilever beams fails in shear even if the size is increased. Can torsional modifier of 0.001 be applied on these beams considering the case of compatibility torsion? or is this the case of equilibrium torsion?
    • Dear Members,   I am currently designing a warehouse with a span of 125'-0". The structure is being modeled as a metal building. Deflection is within allowable limits, but 6" deflection could disrupt roof components. Reducing the deflection further makes the metal building design uneconomical.   To address this, I'm planning to design truss frame for comparison. Could you please recommend a suitable type of truss to resolve these issues? Additionally, any special guidelines for truss design would be greatly appreciated.   Thank you in advance for your assistance.
    • Hi there, I had the same issue, and the FEM results in tables are per unit width (1 m), so Modeled the strips with 1 m width, and the results are way much different (almost 50% less than those on fem results table !! so what would be the problem?
