Detailing related problems
abbaskhan2294
Hello everyone. I want to know couple of things related to detailing in RCC particularly column as;
1) Is there any limit imposed by ACI on percentage of curtailment of bars in the columns located at at two different levels? Lets say; I want to extend 12#8 bars from 24#8 (almost 50% curtailment). Is there any permissible limit for this curtailment.
2) Is there any provision in the code for the splicing of two different bar sizes in columns extending from the bottom level to top; lets say splicing #8 (extended from bottom story column) with #6 (right above).
Salam Abbas,
1- You can do curtailment if your analysis support it but 50 percent curtailment is unrealistic.
2-You can splice any bar size with any bar size, lap length requirement will be as per greater bar size.
47 minutes ago, waqar saleem said:
Salam Abbas,
Wassalam Waqar. Thanks for taking out time and addressing my query. I'm looking for these statements with a reference document (if available). Can you please provide some references that can clarify these points to me?
Edited by abbaskhan2294
21 minutes ago, abbaskhan2294 said:
I'm looking for this with a reference document. Can you please provide some references that can clarify these points to me?
12.16.2 of ACI 318-02 mentions lab splices of different sizes, you may check for the latest version.
