Minaret Analysis and Design
Shahzad Khan
I am trying to understand the analyses of the Minaret. Beside shared an article here in this discussion, i found detail procedure on slide share also. Currently i am pre processing the geometry in ETABS. A snapshot is attached from architectural drawings (Although not good in sectional detailing) along with another snapshot attached from ETABS (which i am working on now  ). My questions are;
  1. How to decide the minimum dimensions for the columns upon which the minaret to be designed (Is it iterative based in ETABS. I mean to select varying cross sections and analyses it?
  2. In the ETABS model (Second picture with out slab and third one with line elements), the  beam in the intersection with the columns. Is it okay to design geometry in this manner?
  3. As the beam column joint here will be most critical region in term of lateral forces resistance. Which type of slab i should consider? Shell thick is okay?
  4. Is there any literature, which give guidance on reducing the column section with elevation? If yes, please share.
Some question, i will add in the comments of this conversation, if required.
I would suggest that you design the minaret as a wall. You can use section designer and check the reinforcement. That representation is better suited. Then based on results, you would know if it is acceptable or not.
Thanks!
  On 1/20/2021 at 9:15 AM, Tufail Mabood said:
Thanks!
What kind of section would you like to recommend. I have confusion in deciding. There are two constrains which i am not able to handle. those are:
  1. Orientation in the minaret part (Up to some height in middle is a constant section, while on the same rectangular assembly, there is another rectangle which is rotated (45 deg) about its centroid axes along the centreline?.
  2. How to handle opening in the section designer, if I choose the complete tube section in section designer?.
Please elaborate, if possible.
It can be any kind. You need to meet architectural requirements.
You can make two different custom sections in section designer. Use one section for bottom and other for the rest.
I believe Section Designer can handle openings. If not, you can draw walls. I would suggest you to check ETABS Watch and Learn on Section Designer.
