Beam Moment Release in RCC Frame
Ali Shan
I have a 3 story RCC Frame. During construction phase, it was revealed that columns of the frame were under-designed (provided reinforcement is 3% and required is 4.2%. Columns have been constructed upto first slab level and beams/slabs have not been laid yet.
We are thinking to redesign the frame by releasing moments at ends of RCC beams (which have not been laid yet) so that moments in columns can be minimised and the previously provided 3% steel in columns may become sufficient.
Is the approach of releasing beam end moments in RCC Frame (with monolithic beam to column joints) correct??
How we will detail the joint? What will be the degree of cracking at joints when beam ends will rotate??
Has anyone ever experienced such deign?
Hi Ali,
End release is not preferred in concrete elements since it will require to allow for some cracks on beams and also difficult to detail in drawings
Releasing frames may touch the stability also of the lateral framing system unless you have another existing system cover this.
You may design column as flexure member by adding localized reinforcement covering moment only from one side and can be developed from one side to the beam/slab
This is an interesting situation.
I also agree with @Ebeid that releasing beams wouldn't be a wise thing to do as it will also effect lateral force resisting system.
The frist thing that I would suggest would be to sharpen the pencil and see if the loads have any contingency and remove that contingency from loads and checking if the provided reinforcement in the column works.
If that doesn't work, you can add more columns per bay to make things work but it would require new foundations.
