Diaphragm in ETABS
Saugat Humagain
First we need to understand the purpose of diaphragm. The main function is to transfer lateral loads to the vertical resisting components of a structure (such as shear walls or frames).
Diaphragm are by default applied to the slab elements even you select whole geometry.
D
In thermal analysis, i believe diaphragm  is not required.  Further to that, no diaphragms are assigned to the slabs in the above model, to allow the slab to expand and contract as required under thermal effects.
Appreciate if senior can comments on that.
I think diaphragm assignment will cancel out opposite forces but still there will be pass through forces that will be required for design.
In general, for thermal loads, it all depends how you apply your thermal loads. Say if you have a top roof slab where the outer side is exposed to sun and inner side is exposed to air conditioning, the temperature variation will produce bending moment in the slab.
I am in doubt about point 1. To provide diaphragm on the areas where we are applying the temp loads will be non conservative.
May be by applying the temp load going to help us in terms of slab deflection like soil pressure ( lateral pressure ) apply on the retaining walls reduced the long term deflection value?
Temp Analysis.pdf
