Beam torsion in ETABS
Moutasem Abdulrahman
Salam Alaikom, i am facing issue regarding beam torsion in ETABS, some of my beams fail in torsion whatever depth i choose, i checked my beams in SAFE and they all are passing, can anyone explain to me this situation? which is more accurate in beam design? can i ignore torsion in internal beams in ETABS?
1 hour ago, Bahram Kiani said:
Common practice we follow in Pakistan for this problem is to reduce the torsion modifier to 0.01.
Detailed discussion on this topic :
I have read what is been said , however i have applied the torsion stiffness modification factor (0.01) for some of my beams however they are still failing due to torsion, however they pass in safe. so what to do?
