Analysis and design of slab resting directly on masonry walls
Aslamoalaikum.
I want to design first floor + ground floor slab of a school (5 classrooms + 1 bathroom + 1 office). Slab rests directly on the masonry walls. Thickness of all walls in superstructure is 9". Typical stepped masonry footing (13.5" / 18") is provided.
How can I model such structure in ETABS / SAFE?
W.Salaam,
There is a lot of recent posts on the forum about designing masonry in ETBAS/Safe. I would suggest you to search the forum to get the required answer. However, please note that we don't recommend using ETABS for Masonry design as it is a frame analysis software. You should either try locating a masonry design software or buy a masonry text book and follow the examples.
Regards,
