CRUSHING FORCE
Muhammad Hashmi
Assalam O Alykum
Dear senior,
Due to the requirement from architect in one of our reinforced concrete building. I am struggling to find out the possible solution. Can anybody please help in this regard?
Scenario & problems
1.       Architect want to increase the size of opening at 5th floor around 2.5m approximately.
2.       Existing beam at 4th floor is not capable of taking load of pick up column carrying 2 additional floors.
3.       What I am doing is take the column coming at grid line “10” up to 1.0m height and provide the additional proposed beam of 50x70 (inverted) and starts the pickup column from that beam and keep the gap between existing beam and proposed beam without providing shear studs / key.
4.       Problem is axial force is shown on the proposed beam of approximately 1381 KN. I want to know this value will be compare against which value. I mean carrying capacity. Second do you suggest to connect both beams by means of shear studs or key is better or proposed beam will rest on the existing beam by bearing is good proposal.
5.       Another query that looks stupid might be is that ,any specified material that can be used on the top concrete surface of existing beam so that it will work as a reinforcement without providing a shear stud / key for example built in composite corrugated decking P2623 Canam.
I am trying to simplify the issue by sending supporting pdf extracted from models. If anybody can give some time to sort it out.
Thank you
MARKUPS SGH.pdfFetching info...
I am not able to understand how can there be a demand of 1380kN axial force on this beam. Any way, you will design this member for combined axial+flexural actions, meaning it should be treated as column. Draw interaction diagram, and see if Pu, Mu falls within the envelope.
it depends on the demand-to capacity ratio.
