Back-span requirements for a cantilever beam supported on wall.
abbaskhan2294
14 hours ago, Badar (BAZ) said:
There is no code requirement for it. You will need to make sure that enough length is available for the development of reinforcement at the critical x-section. Also insure the rotational stability keeping statics in mind, if it is critical.
So the backspan has to counteract same moment as that of the cantilever. Is that all I need to care about? Development length offcourse would be fulfilled by meeting criteria no.1
Edited by abbaskhan2294
Backspan is there as it needs to meet development requirement. That is the only purpose.
What Baz is referring to is the Stability Requirements at Cantilever root (see snapshot below for understanding). What that means is that your beam at location where it is supported on the wall should have lateral stability (either other beams coming from the side frame into your cantilever beam, or something stopping your cantilever beam from twisting). These requirements are well understood in steel design. I am attached a document that can provide you some insight from steel point of view. You can take that understanding related to stability and apply to concrete.
Cantilever Beams_Steel.pdf
