Assalam O Alykum
We are specifying in our structural drawings that
"ALL REINFORCEMENT SHALL BE BASED ON ASTM A615 WITH 460 N/mm² MINIMUM YIELD STRENGTH."
My question is shall we rely on the yield strength mentioned on the mill certificates provided by the reinforcement suppliers to design our reinforced concrete members
I am attaching most famous reinforcement providers in KSA ( SABIC STEEL) where all the rebars having yield strength is more than ASTM standards and all the mechanical and chemical compositions are with in allowable limits.
Will be helpful if seniors can comment on this.
Thank you
SABIC LATEST MTC NOV 29 2017 pc.pdfFetching info...
W.salaam,
My suggestion would be that you still use the minimum specified yield strength of 460 MPa, as you are testing limited number of bars out of of thousands of bars that will be used for the structure. Also, it is good to keep some contingency as there are a lot of assumptions and limitations involved.
