Etabs Rc Design: Reinforcement to be designed or Checked for columns
Azshah
i want to ask if the columns of an RC multistory building have to pass both as "reinforcement to be checked" and "reinforcement to be designed" in ETABS V16.
i am working on a project in which when i select the option of reinf. to be checked and provide reinf., the design is ok. whereas if on the same model when i select the option of
reinf. to be designed, failures are shown such as BCC failures.
i presume a structure has to pass both.
guidance is needed
guidance is needed
Azshah,
Reinforcement to be checked should be used when you "Define" the column reinforcement and provide the steel which you plan to provide on drawings. Normally this option is used when you are checking existing brown field structure where reinforcement is known.
When you want ETABS to design the reinforcement (tell you how much is required), you go with reinforcement to be designed and provide that reinforcement.
