sub frame analysis --manual vs etabs results
d.malan9
Hi all,
I have done a sub frame analysis using manual calculation and modeled the same with etabs. However I see a significant difference between moments at ends of beams when comparing the results. What have I done wrong when modeling the frame in ETABS.
Column sizes 300mmx300mm
4.EDB Input details.pdf manula results.pdf Section T Beam.pdf
On 4/20/2021 at 12:58 PM, Badar (BAZ) said:
Looking at the results of mid-span and at interior support, a difference of 2% in results is not "significant" at all. You have not done anything wrong.
Okay. Finally I found the reason for the difference of the results. It was due to the fact that manual calculation was done on the assumption of a rigid frame where no joint translations where as etabs did the calculation with joint translations which affeected the results. I assigned restraints to joints and then results were a match. Thank you for the support. Greetings from Sri Lanka.
On 4/26/2021 at 11:22 AM, Badar (BAZ) said:
By joint translation, you mean that the manual calculations were based on the assumption that frame can not move side ways?
Anyways, for practical purposes, this is not a significant difference.
side ways and no support settlements ( No vertical displacements). Since the structure was symmetrically loaded there were no lateral forces expcept vertical displacements were taken in to account in ETABS. That was restrained and results were almost the same.
