Concrete Slab Detailing
sochtheking
Hello all,
I had a question regarding reinforcement detailing. I am using ACI coefficient method for slab design, so I am getting reinforcement requirements for each panel. If I had two slabs which are adjacent that have different reinforcement spacing requirements. Do I just detail it as it is? or Do I pick the one that is more critical? (To align reinforcement for both panels)
Example: Panel #1 requires #4 @ 10 inches and Panel #2 requires #4 @ 8 inches, I am scared that at the beam connecting them B1, it will be too cluttered.
Thank you in advance for your advice.
Edited by sochtheking
Thank you for the response Badar. Another question is, if I have the spacing for the negative moment to be #8 @ 250 mm for example, but for positive moment it is #8 @ 300m running along the x-axis, how do I detail this? This means that the positive and negative are misaligned in due to its difference in spacing. Should I make the positive spacing same as negative or should I just leave it as is.
Please disregard my last question, it has been sorted out. However, is there a way to input my hand calculated slab design into ETABs to check if the design has passed or failed. I am having trouble finding an option for this
