stiffness matrix from mode shape
Ayman
Hello,
I am a master research student. Actually, I am working on the assessment of the dynamic behavior of the non structural components on the modal properties of the building. I am trying to determine the stiffness matrix from mode shape. Is it possible to determine the K matrix? From the MPMR table, I realized that there is a higher mode effect (to reach the 90%). What is the best method to determine the stiffness matrix?
Edited by Ayman
Thank you Umar for your response.
Usually, this is the typical method. But, i have ambient vibration measurements for the building, these measurements give the mode shape, so i need to use them to determine the stiffness matrix ( i have also the mass matrix M). The aim of my research is to model a 3D building and simplify it to a 2D model and compare the results.
My pleasure Ayman. One way to solve this would be to measure force causing this ambient vibrations using strain gauges that measure strain in structural members that can be convert back to force .. This will involve some assumptions and simplifications as well.
I have a vague idea on how to approach it. But, yo should ask this question to some one in academics. Most of the practicing structural engineers do not need to do this in their projects; if you dot not do something often, then that concept goes away after period of time.
Vague Idea
for a particular mode: mass matrix x acceleration matrix + stiffness matrix x displacement matrix = 0
You can get mass, acceleration and displacement data for a particular mode and then work out stiffness matrix.
I am not sure if it will be helpful or not.
