Modelling Steel Truss with Overhang on ETABS
sochtheking
Hi,
I am currently modelling a stress roof truss on ETABs, the truss has an overhang. I am having trouble modelling it as I keep getting this message:
Load Case : Solving Linear Stiffness from Zero (unstressed) initial conditions
THE STRUCTURE IS UNSTABLE OR ILL-CONDITIONED !!. CHECK THE STRUCTURE CAREFULLY FOR. TO OBTAIN FURTHER INFORMATION:. - USE THE STANDARD SOLVER, OR. - RUN AN EIGEN ANALYSIS USING AUTO FREQUENCY SHIFTING (WITH. ADDITIONAL MASS IF NEEDED) AND INVESTIGATE THE MODE SHAPES
Can anyone help with this?
I have attached screenshot of the roof truss.
Thank you in advance,
  On 6/30/2021 at 4:35 AM, sochtheking said:
Hi,
For trusses, all members should be pinned but any cantilever members that go beyond the support should be modelled, designed and detailed as continuous/ moment connections or else the system would be unstable. What are your boundary condition for these truss members that cantilever?
