Construction Joint Detailing
Hamza Irshad
Salam,
i) Is it good to provide 45 degree angle between proceeding and succeeding Raft at construction joint for shear transfer or we must provide key or diagonal dowels at joint as shown in figures below.
ii) My second question how we can decide size of key between proceeding and succeeding Raft part.
On 7/10/2021 at 6:51 PM, UmarMakhzumi said:
Hamza,
To size, find the moment and shear at the section where the two rafts meet and ensure you have 1) enough flexural rebar 2) enough ties or shear capacity (Chapter 17 ACI 318-14) for shear limit states.
Dear Umar Bhai why shorter directions are preferred for construction joint over larger direction? Is it because of the controlled shear demands in the shorter as compared to the longer ones? please enlighten your knowledge on this. Thanks
Dear Abbas,
Probably because short side means less construction works especially for sawed-joints. I would suggest checking out ACI 224 as it is the go to document for constructions joints for more info. Hope that helps.
https://www.concrete.org/store/productdetail.aspx?ItemID=224395&Format=DOWNLOAD&Language=English&Units=US_AND_METRIC
