Beams
Moses Fukiza
 There is no beam-slab connection approach in ETABS. It can include the stiffness of flange automatically if you have defined a shell element for representing your slab, but it will calculate the required flexural rebars based on the cross-section defined for the line (beam) element.
Define a T-section if you want include the effect of flange for positive-moment  capacity. In that case, you need to model the slab carefully; area element with shell property can result in over-estimation of stiffness if stiffness modifiers are not applied appropriately.
