Scale factor response spectrum
Muhammad Hashmi
Assalam O Alykum
I am having confusion by applying scale factor in E-tabs program in response spectrum mode after performing 2 different checks
Check number-1
1. After getting more than 90% of mass participation factor along Ux , Uy direction and get the displacement value for example In Ux
I multiplied the elastic displacement value of Ux by x Cd/I to get the In-elastic displacement .
Delta In-elastic = 18.5x4.5/1.5 = 55.5mm
Check number-2
2 After getting more than 90% of mass participation factor along Ux , Uy direction
I multiplied the scale factor directly by Cd/I and my assumption is that, by that way program will give Inelastic displacement directly.
But displacement values are not matched in both checks. What will be the possible reason of getting two different values having difference of 15mm.
Is my question is clear yes / no
Anybody can advise specially seniors
W.salaam Hashmi,
For the check 2, your base shear is different and so is deflection. What is the basis of this check?
