Seismic factors (kv/kh or cv/ch) values
Omer Ahmed
Hi all, I need  some help with retaining wall design. How seismic factors kv/kh (as in UBC97) or cv/ch (as in BCP) are calculated? also how to develop relation between seismic zone of BCP and UBC97? I mean Islamabad/RWP is classified as  Zone 2B (PGA value: 1.6-2.4) however same city is classified as Seismic zone 4 in UBC-97, now the problem is that modern software uses IBC so I can used data of UBC97 but how do I find equivalence of seismic zone?
Many thanks
It is incorrect. You cannot get the seismic information of Pakistan from UBC 97.
It has been discussed somewhere else in the forum. The difference between new set of codes and UBC97, and earlier codes, is in the definition of design grounds motion parameters and design earthquake.
In Pakistani code, seismic forces of structure are still based on expected  ground accelerations at site; they are expressed in terms of Ca & Cv (same as in UBC 97). Since 2000, codes no longer use them, instead they have developed zoning maps in term of design spectral accelerations at short period, Sds, and 1 second, S1 (it is argued that they represent the seismic input energy better than Ca and Cv). If you want to use ASCE, you need "Sds" and "S1" for your site; these values have been reported by several researchers (take a look at the publications listed below) for different regions of Pakistan. You will also find them, hopefully, in new code of Pakistan.
Probabilistic Seismic Hazard Analysis Based Zoning Map of Pakistan, Journal of Earthquake Engineering
Updated earthquake catalogue for seismic hazard analysis in Pakistan, J Seismology (2018) 22:841–86
