RCDC Crack Width Check
sochtheking
Hello everyone,
I am doing some slab design on RCDC and I went through the design calculations and saw that the thermal cracking was always controlling the amount of bottom reinforcement required. Is the reinforcement requirement here different from the shrinkage/temperature reinforcement required? (0.0018bh) Is it recommended to always do the crack width check on RCDC and limit it to 0.2mm. Please let me know, thank you.
On 8/22/2021 at 9:47 PM, sochtheking said:
thermal cracking
Hi @sochtheking,
What does the design report say to limit state of thermal cracking? The 0.0018 or 0.002*BH is termed as “Temperature and Shrinkage Reinforcement “. If this is governing, your slab is likely very thick relative to loads. But to answer your question, we need to first look at software design report to first establish what does it refer to when it states Thermal Cracking. Can you please share the detailed design output of slab?
