Type of loads on RC Frame structure
Sameer Khan
Salam,
I am trying to design an RCC Frame structure on ETABS according to ACI318-14.Generally which types of loads shall i assign on structure ? Plus should i design with the default load combinations that etabs has from that code. Thanks
Walaicum Salaam,
 In General we design Structures for, Dead Loads, Live Loads, Super dead loads, Collateral loads. Wind Loads, Seismic Loads and, Snow loads (For Special Regions).
There are some special cases for pump rooms or Parking areas or Storage tank etc. You have to consider those as well.
Regarding Load combinations, You can go bothways. I suggest you define your own Combinations as to get aware of things. I Suggest you to read ASCE-10 before you go in to modelling process.
Regards !!
12 hours ago, SMAQ said:
Walaicum Salaam,
Regards !!
Thank you for your reply. I believe you're referring to "ASCE/SEI 7-10" by ASCE-10.
And brother please refer or give me any more reading material on RCC design apart from codes and those usual Nilson/McCormic books. Thanks
  • 4 months later...
You can use default design combinations in ETABS, but make sure you design preferences are accurate before using default design combos.
For Loads on structures kindly watch this:
https://www.linkedin.com/posts/mqasimnawaz_structural-concrete-design-activity-6905953661353357312-8R9q
Edited by Nawaz Qasim
spell mistake
