Roof truss deign , member length?
Muhammad SAqib shah
hi guys hope you all are fine ,
coming to the point , i have been modelling trusses for a factory building in ETABS 19 ,details of which are attached ,  span= 90 feet , dist b/w two adjacent trusses is 18 '
horizontal /vertical chords =2L 2.5"x2.5"x3/8" (double angle)
Top chord w-sec 6x8.5
bottom chord w-section =6x20
CGI sheet with 20 psf load on top.
1) the middle portion of the bottom chord is failing i dont know the reason for that ? i have released the moment for each and every joint in the trusses ,
2) should the top chord and bottom chord be 1 member or divided at each intersection with the h/v chords ??
3) the behaviour of the truss is not ok at the mid section , as it should be tension rather than compression ,
 thanks very much in advance ,
cheers
Etabs gives you the reason in its design report; it is clear that your member are failing in compression.
There should be a node.
You are right, you need to take a closer look at your model.
One of the member in your bottom chord seems to be missing as per axial force diagram.
1)Etabs gives you the reason in its design report; it is clear that your member are failing in compression.
reply = the bottom member should be tension member  ?? no ? , why is it in compression ??
2)There should be a node.
reply = sir can you elaborate your point ? you mean the truss should be divided into segments ?
3) sir no segment is missing , you can check in other pix.
dear sir at this point the truss stresses changes from tension to compression ,this member has almost no stress  thats why the diagram is small, any way the prob is some how fixed now there is another big problem , MODAL MASS PARTICIPATION IN x,Z DIRECTION  IS =100 % BUT FOR Y DIR IT IS .46 ,
CAN YOU ENLIGHTEN ME ON THAT PLEASE tt.thumb.PNG.e56f2e7a1472a465ce9b309ef6f39a7e.PNG
  • UmarMakhzumi changed the title to Roof truss deign , member length?
