Steel pedestrain bridge connecting two buildings
Nasreen khushi muhammad
I am working on design of steel pedestrain bridge design connecting two buildings, the bridge is of L shape and need to provide connection between two trusses if my respected seniors have relevant experience then please share or if not then please guide me what considerations have to kept in that case . I will be obliged
1)The bridge will stay on concrete columns of 1'x1' is this size will be sufficient ?
2) is the connection between two trusses will be safe ,no vehicular load will be there in bridge only for humans
The dotted line in fig is the case , the length of one side bridge is of 13ft , the square rectangles are the columns already existing.
I will be greatfull for any reviews and help in this case
Edited by Nasreen khushi muhammad
To clarify more things in question
Nasreen,
For your question:
You need to do analysis for the bridge considering environmental loads like snow, wind, seismic, and dead load with pedestrian loading and see if this will be okay or not.
What is the basis of your design? How are you designing this connection. What limit states are you checking.
