Overstrength Factor Dilemma
Asif Mostafa
9 hours ago, Asif Mostafa said:
Should you design the beams connecting to a shear wall in a two way slab system having beams (both internal and external) incorporating overstrength factor?
Baz has put it well. You need to identify your collectors and design those for overstrength LCs. Most likely the beams connecting to shear wall will fall under this. Also look up your the code and see what it says. For Steel AISC 360 is very clear on which members to use over strength.
