Two way slab in steel steucture
Symon22
Hi , I'm designing a steel structure without secondary beams and want to use two-way slab for stories.
Should I define slab section as shell-thin or membrane?
How can I connect concrete slab to steel beams?
If there are no secondary beams and there the slab is pure concrete slab, you can use shell elements. just make sure your boundary conditions represent the connection you select with steel.
You can use Nelson studs. They transfer shear only with limited tension so you need to model the slab boundary conditions accordingly.
Thank you sir
But how can I model the beams in ETABS? Should I design the beams as composite beam or it's better to design them as SCBF or OCBF to affect the seismic in them?
