Rectification
Ingyin Khaing
  On 4/10/2022 at 6:48 AM, Ingyin Khaing said:
How to rectify the misalignment of column center?
Is this a construction problem like is the column erected out of plumb?
You can check a titled column in your software and see if it still passes with P-Delta.
Other items you can do is change the framing add new columns to reduce load on that column.
