Concrete compressive strength evaluation of bored piles
abbaskhan2294
Hello members I hope this thread finds you well.
My query today is related to compressive strength of concrete bored piles. The issue is that pilegroup with 24 no of piles have been casted almost two years ago but there were observations regarding quality control on couple of piles in the group which are not known. Now the higher-ups are recommending to resume the project again and unfortunately I'm the incumbent and have to propose a methodology. Now the question is that since the piles are already buried underground, which procedure shall be adopted to predict its compressive strength near to its actual. Your suggestions will highly be appreciated. Thanks.
Edited by abbaskhan2294
Hi Abbas
The special GPR (Ground penetration Radar test) looks suitable for your case that is generally applied to check the workability of concrete joint ,  honey comb , cold joint or weak concrete , change in properties of material. Voids and cracks by using electromagnetic radiation for that type of structure.
7 hours ago, Muhammad Hashmi said:
Hi Abbas
Thanks bro for your reply. Exactly what I have been thinking to adopt. If there is any pile that is not meeting the standards will definitely have a changed profile and will be helpful in indicating the defective pile. In addition destructive tests on extracted cores will aide to the investigation.
There are different way depending upon the risk category of the structure.
Pile capacity of concrete is one things and geotechnical capacity is another. The best way would be to do a pile load test on this pile group. Geotechnical consultants normally do such test and it helps verify capacity of existing piles both structurally and geotechnically.
For concrete strength, like you said core testing is one way. I am not familiar with GPR for strength testing of concrete piles. I have seen a lot of results of GPR surverys to find buried lines but nothing to determine strength.
Hope this helps.
Hope this helps.
The full scale pile group load test would be quite difficult to execute + due to defective piles there are greater chances of settlement and thus making the entire pile group sink as a result extra loss to the contractor and a complete failure of project. So I would rather opt for concrete core tests. In addition GPR will be useful in giving idea about the condition of pile. So any pile with weak concrete mix will possibly be identified using GPR as per my observations.
